Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
most nforce 2 boards allow for the memory to be clocked seperately, but for best results go with the higher speed, as lower speed, higer latency memory can cause a bottle neck on your overclock. corsair is excellent. These seem to be cas3 ddr - you might want to go cas2.5 as they should have a bit more room for stability.
