- Jun 9, 2003
Morning everyone. I recently decided to upgrade my Catalyst 11.5 to 11.6 through my normal method - uninstall 11.5 (Express uninstall, remove completely, reboot) and reinstall 11.6. This time something odd happened - though 11.6 installed it noted there was something to look at in the logfile - it turns out that the Stream/Parallel processing/OpenCL item couldn't install.
I went to AMD's website and pulled down the individual 11.6 OpenCL package and tried to install. According to Windows, there is already a version of this software installed and I need to uninstall it first. Unfortunately, I don't see where that could be? AMD Catalyst Install Manager doesn't even show it as one of the components. There's no separate OpenCL or another AMD item in the uninstall Control Panel area. Now, going into my program files (x86) I can find a AMD APP directory with a couple of exes in it and nothing else. I thought I'd check with the forum before I attempt to just delete that folder.
Any idea? I'd hate to have to find some driver cleaner and go into safe mode and all of that, so if someone knows a good solution or has been through this before, let me know? Thanks!
