Ambidextrous wireless mouse for large hands?
veritas7
I have a very "large" request (heh, puns) to ask. Does anyone know of any ambidextrous wireless mice that fit comfortably with large hands?
I can't really find one that fits both... either it's a good fit for large hands, but only for righties...vice versa...
Normally I'd go lefty (since I'm ambidextrous) but my girlfriend is righty so I'm leaning towards one that can handle both lefties and righties decently...
Your request is rather "rare" (heh, failed at puns), but I quick glance shows that only my Microsoft Blue would be compatible for right and left, and its over 8 years old (and still works).
its wired as well, so that may not be what you are looking for (I assume you want to switch on the fly)
My advice is stick with right handed mice, Mice ergonomics now only allow for left, and right. But before committing, you may get some advice from other posters as well.
I've had a hard time finding ambi-mice as well. I'm left-handed, but my wife and kids are right-handed. I've used a right-handed mouse (Logitech G5 to be exact) for so long that I doubt I could even use a mouse with my left hand. :)
Currently I use an MX1000... but they aren't made anymore, and the one I'm using keeps skipping around and I've smacked it around due to so, probably making it worse. The left and right click buttons are also timid, as they decide to double click when I just press them once. I'm ready to throw this guy out at the moment, as I'm currently using my right handed wired gaming mouse :\
Oh man. I totally forgot, it should be rechargeable. I think I'm just going to go righty, at least it gives a tad more options then.
Argh, this mouse is getting to me. It keeps hitting "dead spots" on my razer mousepad. Annoying as hell :\ My other mice are perfectly fine. POS Logitech >:|
Edit: I realize it's the LASER that's the problem. My current mouse scatters on my razer matpad, but works fine on everything else. I don't know why so many companies like laser. My optical Razer Deathadder I use for gaming is perfect. I wish there were more optical wireless mice.
Even though I've seen some of the problems with it, I might take the plunge and splurge on the Razer Mamba. I just want a damn mouse that doesn't skip around on any surface, wireless, and recharges. FFFF >:|
