Hey all,
Sorry for asking such an amateur question, but is there any appreciable difference in reliability when one uses high-end HDD (Enterprise class) or Desktop grade HDD's for backups and Archiving as opposed to using Archive HDD's?
I have always been under the impression that archive HDD's are of the lowest grade in quality, and thus cheapest and ideal for backups, but, except for Enterprise drives (which are too expensive for my use), I am willing to spend extra for a higher grade HDD if it means my data will be safer.
The main use would be backing up, so writes to them will not be often, and will do some reading off them (archiving ripped movies etc).
I have access to Toshiba, WD and Seagate drives, with a HGST NAS drives on the side.
Thanks!
Thanks!
