I can't tell on the radiator or res, but the CPU block is a DTek Fuzion V2 OEM and the pump is a Laing DDC of some sort...could be a knockoff, I can't tell.
In short, I agree with King Icewind... you'll be happier piecing together your own system.
You could easily put that kit together yourself with a D-TEK Fuzion v2 water block, an MCR220 rad, a Laing DDC 3.25/MCP 355 pump, and an EK res and some masterkleer tubing.
