The table shows the ASUS Cross-hair 6 Hero able to do an OC 3950x, 200a. Man the newer boards are nice but really overkill as well. Hoping to hear about Ryzen 3 TR before the 3950x is released in September. Very exciting time.
Yes indeed, may just stick the 3900x in her which should have zero issues overall, put the 2700 in the Biostar board retiring my second 1700x or sell it on eBay.That is what most people said about C6H that it was overkill as well![]()
Amazing! Now I have no idea why some of the X570 boards have such beefy VRMs. Some are reporting at Overclock.net that the ASUS newest ASUS Crosshair 6 Hero also has PCIe 4 options - not sure if one can enable or not or how stable it would be.Techpowerup tested VRM temps on a B350 board----with an overclocked 3900x
https://www.techpowerup.com/review/amd-ryzen-9-3900x-tested-on-cheap-b350-motherboard/4.html
The TLDR is use an air cooler for your CPU or point some case fans at the CPU socket/VRM area, if you watercool. And then things are generally fine and functional. Although of course, a slightly better board is recommend. As it did temp throttle in a couple of especially brutal tests.
Looks like a stock 3900x would be just fine.
Pardon my lack of knowledge in this area. So the gigabyte boards are the better quality ones? They have the highest number of phases
I found it interesting that Asus uses no doublers on the power phases and instead uses up to 3 mosfets per phase. So, one of their "12 +2 phase dr mos" designs has 4 primary phases with 3 mosfets per phase. Is that cool? Seems most other companies are using doublers for almost all of their designs with a few exceptions.
Yeah your assumption is correct. As buildzoid explains in some of his videos -- you get a bit better transient response by not using the doublers. You can just ramp the frequency of the VRM if you wanted but honestly it's a perfectly fine solution.If someone tells me they have 12 phases I expect 12 equally spaced phases. Putting three mosfets on a phase doesn't make it 3 phases... if I am reading what your wrote correctly. It's just one phase with (in an ideal world) 3x the current capability.
Or watch his current video's where he goes over the X570 boards. This is not the case.Be really careful with Gigabyte and their claimed phases. Buildzoid did a video not too far back where he criticized them for basically advertising phases in a way that is basically deceptive. I guess MSI was doing the same thing for a while until he called them out on it and they took it out of their product descriptions.
Every company makes a bad board. All of them do. Do not brand a company because they put out a shit board, as Buildzoid explains, they all have turds in their line-up.
Gigabyte's X570 seems to be the best so far. Buildzoid basically declared it the perfect board but said he would never buy it because like all flag-ship X570 boards, it is ridiculously over priced.
My apologizes. No offense intended, just thought it was relevant.This thread was about 300 and 400 series motherboards and their VRM quality and ability to handle Zen 2 CPUs. Why would I go watch videos about X570? I don't even know that the Gigabyte boards in question where bad, only that Buildzoid called them out for shady shit.
