There have been reports that the through board cooler mounting holes have changed from 96 x 48 mm of AM3+
to 90 X 54 mm of AM4.
source 2016-11-19
http://xtreview.com/addcomment-id-46524-view-Differences-in-the-fastening-system-Socket-AM4.html
A new image of an ASUS A320M-C motherboard from a nearly plan view has appeared.
Source
https://nl.hardware.info/product/378863/asus-a320m-c/reviews
I thought I would scale this image and check the dimensions.
This is based on the assumption that the pin spacing is 1mm, giving 38mm across the 39 pins.
The 90 x 54 is with in the margin of error of the scaling but not knowing how the back plate was measured 90 x 54.5mm maybe more accurate.
source 2016-11-19
Source
