AM3 or i7 core build under $700???
paco16
I'm upgrading my old Nforce4 Socket 939 SLi build for a new and improved version. I've always tried to do one upgrade every 3 or so years, (paging the first SLi dual-core chipset...6 years ago), but I do my research.
Here's the scoop-
I already have the extra's (i.e.- Case(XClio 380), power supply(Enermax 720), drives(all SATA), sound card(X-Fi Fatal1ty Champion Series), video cards(2x8800 GT's)).
The i7 Platform-
Here are the parts: Gigabyte GA-EX58-UD4 or Biostar TpowerX58, Intel Core i7 920 Nehalem 2.66GHz, OCZ Platinum 3GB (3 x 1GB) DDR3 1333, Vista Home Premium SP1 64-bit.Total:$716.96
I think I can get the price lower if I buy G-Skill or Geil high latency ram, but I am a huge fan of Corsair and OCZ. I have little to no experience with either of the G-companies.
I need to pick between the two boards. Any takers?
I could be wrong but I'm pretty sure the DS4 doesn't support SLI. I think it only supports Crossfire. I'm also assuming you want SLI with 2x8800GT's. Also, if you drop the Vista Ultimate for Vista Home Premium, that would get you under the $700 mark. Other than that, I don't see how you can get the i7 under that mark. If I were you though, I would wait another week or two and save the extra $63.97 and go with the i7 and you might actually find something a little cheaper. I'm waiting to go i7 but my budget is $600. I'm going to have to wait a little while I'm afraid.
Nope, not every x58 mobo is certified (i.e. licensed by nvidia) to handle SLI, so...
According to a review on the web (Link), the GA-EX58-DS4 only supports CrossFireX, the GA-EX58-UD4P supports both CrossFireX and SLI:
GA-EX58-DS4 Unique Features
* Three PCI-Express 2.0 x16 slots locked to x16, x8, x8 respectively
* ATI CrossFireX support
* Realtek ALC888 7.1 channel High-Definition audio codec
GA-EX58-UD4P Unique Features
* Three PCI-Express 2.0 x16 slots x16, x16/x8, x8
* ATI CrossFireX and Nvidia SLI support
* Realtek ALC889a 7.1 channel High-Definition audio codec with Dolby Home Theatre support
Thanks for the notification on the DS4 not supporting SLi. I checked: only supports x-fire. I have updated the original post with a new mobo and price.
Don't worry about latency with DDR3 and tri-channel on the i7. It has so much memory speed it doesn't know what to do with it all. Honestly, that AM3 final price looks a bit high. I bet I can shave off another $100 easy without sacrificing quality or performance.
The GIGABYTE GA-EX58-UD3R also does not support SLI. Only xfire. They claim to have an SLI version of it, but I haven't seen it around.
My preference is to go with i7 because it's so damn close to $700 and I've already convinced my financial adviser (the wife) that $700 is the price-point we need to be at. Multiple factors go into my thought process. Here's the priority string ranking high to low: (price, future-proof, performance, shininess :cool:) I'd be more willing to go the AM3 route if AMD had a chip that was close to the base-line i7.
So I guess if you could keep those core parts under $700 with comparable performance to a base-line i7... I might bite. Believe me I want to go AMD. I'm still on a dual-core opteron socket 939 and it still plays FarCry2 at 1900x1200 and Crysis is jacked all the way (other than the shaders) with 40+fps.
Also, that Biostar mobo is AM2/AM2+. I don't want to muck around with "compatible" chip-sockets. I want to go full AM3. Sorry to be picky, but for an upgrade every 3-6 years...I have to be.
I don't see why you would compare two system configurations where you changed the OS from a relatively cheap option (Vista Premium) to its much more expensive counterpart (Vista Ultimate) and you also added in expensive CPU cooler for the AM3 build that you don't have for the Core i7. It doesn't strike me as a very even evaluation between platforms...
Nonetheless...
There are no AM3 boards that support SLI yet. There are AM2+ boards that support SLI and will take AM3 chips however. As ordovician noted, full AM3 boards only support DDR3 so your memory choice needs revising. If you're going AM3, you must use DDR3 and give up your SLI setup.
If you subtract the cost difference of Vista Ultimate and the CPU cooler from the mix, you end up well below your $700 limit.
- A copy of Vista Home Premium 64-bit runs $100 for the OEM version over at Newegg.
- A Gigabyte 790FX AM3 board runs $180.
- The 810 CPU goes for $175.
- 4GB of OCZ Platinum or Corsair XMS DDR3 memory runs $85.
That's only $540 total. Grab a pair of 4870s for CrossFire and you're at about $850. Sell your 8800GTs for $150 for both and you're back down to $700.
So basically, you can either keep your current 8800GTs and go with the i7 which will give you great CPU power and respectable GPU power OR go with a new set of 4870s and go with AM3 which will give you respectable CPU power and great GPU power. All depends on your needs. Can't really go wrong either way though.
lol, I can't help it! Running w/ the 1GB versions would have put him around $800 instead of $700.
Hmm Zoogle... I still think the Phenom 2 720 triple core black edition would be a better choice. It has more cache (6mb as opposed to 4mb), will OC better, AND is cheaper. I also think that a good AM2+ mobo would shave off lots of $$ without a lot of performance loss.
Also look at this, a 1gb 4870 for $188:
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10010072
This ram will do cas 4 with some volts:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
$188 + 209 + 20 = $417 for RAM, Mobo, proc, and vid.
Sorry about the "unmatched" comparisons. I just understood that the i7 could pretty much run on air without a monster cooler and overclock like a champ; so I omitted the $80 cooler to save cost. Also, I have switched both OS's to Vista Home Premium 64bit and this obviously saved another $80.
I'll update the OP in a bit as I'm still struggling with why AM3 boards don't support SLi...
For some reason, I just can't believe it! Why, oh why AMD if you're trying to show people you're becoming competitive again would you not include SLi in your new chipset!?
Has anyone seen/heard anything about the ZOTAC X58SLI-A-E LGA? It's the cheapest i7 board that supports SLi on newegg... Adding this has gotten my price to $713.96 with the OCZ Platinum 6GB (3 x 2GB) DDR3 DDR3 1600 triple channel kit, Vista Home Premium 64 bit and the Intel Core i7 920 Nehalem 2.66GHz.
My question is, I've seen the i7 destroys any and all AMD platforms in all benchmarks and this would give me that "future-proof" system I've been looking for. I can upgrade the CPU later when prices drop more. Thoughts?
Sure you need DDR3 1600? Most 1333 will accomodate good OCs with the i7. Moving my friends i7 rig from 1066 to 1600 in the bios only netted about 2fps in Warhammer Online.
Core i7 920....288
Corsair Dominator 3 x 2GB....185
EVGA X58 SLI tr model.....249
Quality products give quality results.
Buy that Zotac thing and let me know how it works out for you.:eek:
Core i7 920....288
Adding in Windows Vista Premium 64 bit puts me over $800... I understand quality is the best route, but I need to find a way to do this for under $700... or at least around it. I'm on a tight budget.
RAM timings are basically meaningless.
I also second the Phenom 2 720 if you go the AM3 route; It is basically a Phenom II 900 series with a core disabled, whereas the 800 series has L2 cache disabled. The 720 is also a great overclocker.
An AM3 build:
Phenom II 720 - $145
G.SKILL 2*2GB DDR3 1333 - $70
Asus M4A78T-E - $140 - Out of Stock
Subtotal = $355
You'd ned to spend $40-70 for a good heatsink though.
You need a take a look at this comparison of scaling the Phenom II compared to the i7.
I've been struggling with the same question you have, Which is more future proof, the AM3 or the LGA 1366? I've come to the conclusion that the AM3 is more future proof at this point. Mostly because When I spec an AM3 vs LGA 1366, I save ~$300 ($250 if a cheaper mobo is used), so I figure why spend that money now? When I can wait a year or so and get better parts (say RAM + CPU + MOBO, and maybe not even RAM) than the current i7 offerings for a similar price.
"The Phenom system used 4GB of DDR2-1066 RAM in a 2GB/2GB configuration while the Core i7 processors used 4GB of DDR3-1066 in a 2GB-1GB-1GB deployment." Aren't all x58 boards supposed to have matched "triplets" to run triple channel memory correctly? He says this didn't affect the outcome much, but I thought it was the same concept as DDR1&2. Matched sets, one stick for each channel... Am I wrong? Shouldn't it be 2gb-2gb-2gb or 1-1-1?
Either way buying a decent system now for less money and upgrading to the machine I wanted in the first place later seems unrealistic due to our current schedule. I don't even format as much as I should just because I'm so busy throughout the year. (I'm sure no one else in the IT world feels my pain.:D)
Would it make any sense to downgrade to a 1-1-1gig DDR3 kit? I can always get a slightly better board with 6 dimm slots and match them up later... right? The triple channel 3 gig kits are really cheap!
The point isn't to upgrade to the system you wanted in the first place, it's to upgrade to a better system.
I think they can do that (2GB -1GB -1GB) because some motherboards have improved enough to run unmatched pairs in dual/tripple channel memory. Here are some benchmarks on # channels used vs bandwidth, make sure you see the next page as well.
Yeah, if you want to save some dough get a 3*1GB kit or a 2*2GB kit.
can you still get triple channel if you are running 2-2?
Note- for those who don't know/care, I've decided to try and make an i7 system work due to benchmark research and the whole x58 platform in general.
No, that would run in dual channel mode. You could later pop in another 2GB stick for tripple channel or buy a 3*2GB kit.
Ok thought so. Thanks! I just added the ram to my "i7 wishlist" on the egg and I have $50 to play with to change out the Zotac mystery board that supports SLi to a better one. I'm looking now... Btw, the PT6 from Asus is getting slammed in the reviews on newegg. Same with the MSI Platinum x58(tons of DOA's).
GIGABYTE GA-EX58-UD4P or the BIOSTAR TpowerX58? Both are $269.99 but the Gigabyte has a $20mib.
I've heard the Biostar is a true over-clocker's dream, but I've never like any Biostar board. The last Gigabyte mobo I had ran forever, oc'd like a champ and even had great support. Dual-Bios on that old board was a nice feature too...
What I'm looking for is some definitive pro's and con's between the two boards.
The price is perfect on both, and I need SLi support for any x58 board I buy(the 8800gt's are still solid cards).
I'll be putting in a triple channel 3 gig OCZ kit (7-7-7-20 for timings) and an i7 920. I can upgrade with another triple channel 3 gig kit later without degrading performance right?
i think you got that backwards. people have been getting decent OCs from amd stock coolers while i7s need the monster coolers to get the 'champ'-level OCs you've been reading about.
as for why am3 boards don't support sli, those are coming later in march once nvidia board partners get their act together.
An AM3 build:
Subtotal = $355
You'd need to spend $40-70 for a good heatsink though.
that is an excellent choice of components. fully recommended.
some heatsink recommendations much closer to the $40 price point:
free shipping, $10 rebate:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835207004
excellent performer. recommended by many.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029
Not sure if anyone saw my note. I'm buying the i7 config- I decided to drop down the ram to a 3gig triple channel kit and spend a bit more on a good mobo. I need some input on the BIOSTAR TpowerX58 and the GIGABYTE GA-EX58-UD4P.
The Gigabyte board has a $20 rebate as well. Both support SLi and have 6 ram slots so I can upgrade to 6 gigs later on this year.
I've never liked a Biostar board, but I'm not stubborn either... I'm open to shiny suggestion.:cool:
Meh I7 is a waste of money, and so is DDR3. Any Core 2 or PII AM2+ is a much better buy.
You should try one before you bash it.
My system loads so fast I can't read anything.
I upgraded from an OC'd Q6600 and 4 GB of OC'd DDR2 8500 Dominators.
My X58 laughs at that......:D
Paco........I'd buy the Gigabyte board. I've had a number of them and they have always been top notch and great quality. Usually pretty good OC boards too.;)
Eh, not completely. Core i7 doesn't perform as well in gaming as a Core 2 / PII based processor, but it makes up for that fact with it's stellar performance everywhere else. Both the AM2+ and the LGA 775 are virtually dead sockets in my opinion.
review of the GIGABYTE GA-EX58-UD4P and the BIOSTAR Tpower X58 (though I think the BIOSTAR review itself sucks, the review not necessarily the mobo).
