aparently then i've installed all my CPU coolers other than the H50 incorrectly.....my Core Contact Freezer(nearly identicle to the 212+) didnt even come with one.....there is NO REASON to replace the backplate unless the instructions specifically state it....since the majority do come with a metal back plate on it....
I dont have personal experience with the 212+ figured it was identicle mounting, or very similar to the CCF, but it appears CM went with something like a screw in method (unlike all coolers but the H50 that i have used)
have you seen the Core Contact Freezer? It is rather large, and atleast the size of the 212+......i'm just saying i had not run across one that did not use a clip mounting system
stock paste shouldnt put it at 60 at idle/load with stock speeds/voltage.....check what the BIOS is setitng the voltage to....shouldnt be above 1.35v max for stock, can and should be lower
