redbeard75
- Jun 28, 2012
Finally building a new system after too long...been out of the loop for awhile..anyway, I'm struggling with which board to get. I'm limited budget so Intel is no go, the rig will be primarily used for media server, video encoding/transcoding, very light gaming. will be buying from microcenter for the combo discount. Looking at 970 boards as I don't really see paying for features the 990 has but won't use, sli for example.
So far I'm seeing as potential...
asrock 970 performance (8+2 phase , nice sound chip, ?quality?)
Gigabyte ga 970a ud3p (8+2, known quality as I've have 3 gigabytes no issues.)
I will be getting a fx 8320e with evo 212 cooler w/ hopefully an OC to 4-4.2ghz
I've always used gigabyte and had no problems but the asrock looks to have some great features but haven't seen much commented/reviewed about it. So I'm not sure if asrock makes a good board, never owned one.
would like to see what you would recommend, thanks!
