am2 x2 4600 can't cool it down
j282
AMD Athlon 64 X2 4600+ Windsor 2.4GHz Socket AM2 89W Dual-Core Processor Model ADA4600CUBOX - Retail
ASUS M2A-VM AM2 AMD 690G Micro ATX AMD Motherboard - Retail
GIGABYTE GV-NX86T256H GeForce 8600GT 256MB 128-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card - Retail
I purchased the above parts and put them into a thermaltake Lan Lite box for an HTPC. I installed ASUS probe and speed fan and have checked my hardware monitor in the BIOS. At boot up the processor is starting at around 53C under load it hits 63C. I have tried reinstalling the stock heatsink with some artic silver. It feels like its making a good connection with the processor. This is so weird because my place sits at around 62F, the thing should not be getting so hot. The case has a lot of ventilation holes in it, but the power supply sits right over the processor and the video card is passively cooled and sits by the processor.
Anyone had problems with the stock heatsink on this processor? Could this just be the case causing the high temps? What temps should I be reading in speed fan. Temp 1 is listed twice with two different readings. I'm wondering if this is just something wrong with the sensors on the board. Thanks for any feed back.
Speed Fan has temps as follows:
Temp 1 58C
Temp 2 33C
Temp 3 25C
HD1 34C
Temp1 40C
Core 49C
Core 63C
Ambient 0C
I also ran Everest and it showed the CPU temp as 40C. how do I find out which one is accurate.
