Am2 or 939
brichter45
I'm building my first PC. I was planning on going AMD with 939 until recently someone told me to look into AM2 i was wondering the benefits of going to AM2 besides 939. I'm trying to buy a MOBO under 200 dollars so keep that in mind. Thanks
You can find AM2 or 939 motherboards under $50.
AM2:
http://www.newegg.com/Product/Produ...rtyCodeValue=0&Submit=Property&SubCategory=22
939:
AM2 is a newer socket and 939 is going to be phased out sooner (but slowly). AM2 will theoretically have an upgrade path down the way and uses DDR2 instead of DDR. There's not a whole lot of difference between the types of RAM in terms of speed, but DDR2 is now a llittle cheaper.
In the end you should get an AM2 mobo since it costs about the same or only a couple dollars more. The main reason for getting a 939 system would be if you have some DDR ram that you want to use up instead of buying DDR2.
well considering i have bought nothing yet, i'll probably go with the am2, thank you very much for the input.
am2 has a 35% performance increase against the 939. other that am2 can use ddr2, basically that's it.
Uh... maybe 3.5%. Hope that's what you meant.
If you are rebuilding a system all the way down to mobo, cpu, and ram... I'd sure as heck look at alternatives. You at least have to compare an E6400 with conroe mobo to the price you end up with AMD in the cart. Depends what kind of cpu you're going to use costs. I guess the x2 3800+ is still cheaper, higher and I don't know if it's worth the cost savings. Unless you're some kind of diehard AMD'er, the intel rig makes a case for being worth a couple more bucks.
