am2+ need help choosing
XCLR82XTC
yeah i know its old school. my pc for the family uses a quad 9550. i only use it for web surfing and htpc, transcoding vid etc.. so id like to keep in around. anyways, the board is fried so does anyone have a recommendation for a good replacement? i dont care what size, ill put it in a new case if it wont fit the one i have. dont really want a 500 dollar board, just something that will work reliably and give me full function of my processor.
also, the board the quit is a narra 3.. it does NOT support hyper threading, but from what Im reading on line, the phenom (i) 9550 does have it as a feature. so if that is a factor, just getting a board that will enable htt would give me a big boost.
finally, anyway to make it work with ddr3?
thanks!
ps.. im going to be using a 8800gt with the pc. id like to have 2 slots for a second in sli.
Grab any one of the new Asus boards at about $150.00 from Newegg. You will get the processor support, DDR3 support and for your purposes, you will be future proofed for a long time.
If you want to go for price only, you can start at $54.00 and this link will lead to ASUS board sorted by price. Good luck. P.S. Yes they will all support the 9550.
http://www.newegg.com/Product/Produ...625 50001315&IsNodeId=1&name=ASUS&Order=PRICE
No. You are incorrect. Socket AM2+ CPUs will not even physically fit any of the AM3 motherboards because AM3 has only 938 pins while AM2+ has 940 pins. And the AM3+ socket is electrically incompatible with AM2+ CPUs despite the AM3+ socket having 942 pins (this is due to a couple of the pins that are used in the AM2+ that differ from the corresponding pins used in AM3+). And the Phenom x4 9550's IMC supports only DDR2 RAM.
So in other words, the OP will need a new CPU if he is to go with any of those motherboards.
thanks!
What? No Phenom processors have hyperthreading capabilities, only Intel processors have that. Are you talking about hypertransport? That is completely different. Get any AM2+ motherboard and it will have hypertransport.
And yes, as was mentioned above, you are limited to AM2+ motherboards only.
Wow, very helpful, you even linked to FM1 boards.
