AM2+ motherboard recommendation
Nautique
Greetings all,
As my Asus A8N-SLI deluxe proved to be faulty, I am in the market for a new socket AM2+ motherboard. I have searched a bit, and here are my current choices:
Asus M3A78 (Chipset: AMD 770/SB700) Specs
Gigabyte GA-MA770-UD3 (Specs)
I would appreciate any advice regarding these two models, or any other suggestions that meet the following conditions:
- ATX form factor
- Maximum price $100, preferably $90
- Socket AM2+, AM3 ready
- No onboard graphics
- Passively cooled (the cooler the better)
- SLI or Crossfire not required. If there is (particularly Crossfire), then so much the better just in case, but I don't see myself ever using more than one video card.
Thanks a lot for all your help :)
P.S. Should have posted this in the AMD subforum. I'd appreciate it if a mod could move it there as I can't find a way to delete and repost. Sorry for the extra trouble!
both are great mobo. you can't really lose with either. I like Asus placement for front audio on the bottom of the board. Gigabyte have it on the center, next to the audio port, so wire management kinda suck if you want front audio on gigabyte. But the Asus placement of the SATA port might be blocked if you have a big and long graphic card. Just wanna give my 2cent. But both are winners to me :) good luck
Thanks for the information. Indeed, front panel audio wires above the graphics card are a pain. My video card is long, but not THAT long (ATI HD 4830) and I don't think it would have any SATA problems...
Will be glad for any other suggestions, right now I guess I'd be going for the Asus as it's cheaper+has a better layout (the Gigabyte is a bit smaller on size on the one dimension, still ATX though, interestingly).
Only thing I hate about Asus is the one Asus motherboard I had (that faulty A8N-SLI deluxe) had a really un-intuitive BIOS key interface, you had to use + and - to adjust the values instead of the arrows, and could only move with Enter. Not sure if that got any better in recent BIOS...but anyways, I can live with that, as I rarely tamper with BIOS :)
OK, I'm now undecided between ASUS M3A78 and MSI K9A2 NEO-F. Thoughts and suggestions?
For sure the asus board ..its got great reviews and its a full size atx board..has 9 mounting points so the end of the board dosent flex when plugging cables and such..
the gigabyte board is also a good board but the layout on the asus I believe is better and the size of the board has better mounting..
like some of the other posts you really cant go wrong with either board ,its just a matter of which one you like better.....
That's a great mobo but a bit higher on the pricing that I would have liked :) Thanks though, looks like Asus is generally making good boards..
I plan on running the Asus M3A78 with an AMD Athlon X2 7750 Black Edition - Asus website says it is supported, but some people on the net have reported problems running variants of the M3A78 with this processor (system would not POST). Most were caused by RAM incompatibilities it seems. Anyways, I was wondering if anyone here has successfully run the above combination. Lastly, if anyone has some RAM recommendations for this thread, they would help me enormously.
Thanks for all, I'm glad to be part of such a helpful community.
mine works great m3a78-t 7750 check out the qvl for memorybut usually i use ocz or kingston,never had a problem.
