AM2 Motherboard Decision
Massacreinfallx
Hey guys, im here to ask for some advice on wich motherboard i should get. Currently with my 4200+ im running a m2n-e motherboard. Im looking to replace this pretty much because it sucks at over clocking and starves my ram. so here is what iwas thinking..
http://www.newegg.com/Product/CustRatingReview.asp?Item=N82E16813186098
-The Foxconn
OR
http://www.newegg.com/Product/Product.asp?Item=N82E16813136015
- The Infinity
supposedly theyre both great overclockers but what would i get out of the foxconn for that extra 100 bucks?
both nice boards but why dont you wait for the dfi lanparty am2 590 board coming out any day now.dfi said end of august.the board looks really nice.im waiting on the lanparty boards before i make an am2 decision.the lanparty 590 will probubly be aroung 180.00 and hopefully they will have a lanparty ultra also.i saw pictures of the 590 board an brother it looks like a fine board.nice layout and hopefully no as picky with ram as the 939 series......if i had to choose on the 2 boards your asking about id take the foxconn.
you get a nice looking black pcb and a ton more wires with the fox, thats basically the difference
....they give you all that stupid software with the mobo, they dont let you raise yur voltages...and the voltage of your ram is limited to 1.9 volts.
nope.. I can raise my voltages however far.. also, the bios works better than software if you didn't now already. I've had my ram voltage up to 2.2v during my OC testing, and i could still raise it further than that. They have more settings on my new asus board, than any motherboard I have used before, both at work, and at home.
oh i know the bios is better then the software. i m just saying all the annoying software they DO give you is crap. my board has problems after raising my fsb only by like 5
you don't know how to oc then. There are other settings you have to change before you start just trying to raise frequencies and voltages. Read Eclipse's OCing guide if you need help.
Yeah, the new DFI board does look nice. However, according to DFI's spec sheet on their web site, the new lanparty mobo only supports DDR2 533 and 667 ram.
That made me turn away from that mobo...
whats wrong with the m2n-e? i'm running a 3800+.2.4 @ 2.7ghz stable.
plus theres a huge price difference between the dfi and foxconn board.
