O-6 said:If install 4*mem modules on AM2 mobo will they slow down as they did on s939 (4xDDR400 worked as DDR333)?
people still believe that eh? perhaps you should take a look at this. AMD HAS NOT changed the spec to 200mhz at 2T for 4 double rank modules.defaultluser said:That was actually only ealier boards. Most recent 939 boards, coupled with a Venice core processor, will run 4 sticks at DDR 400, with a 2T command rate. It does cause a %1-2 performance hit in games and applications, and about a %5-10 performance hit in certain benchmarks.
But we really have no idea what the AM2 brings to the table. How about you be bold and daring, and find out for us![]()
linkage to where you have discovered this?banGerprawN said:The AM2 MC suffers the same problem that the X2s and Venice-> onwards processors did : It can only support four dimms at 2T, and having all 4 slots populated lowers it's overclocking potential (including lowering latencies to the level that was possible with only 2 dimms.)
Tetrahedron said:bandwidth > speed
burningrave101 said:bandwidth = speed
It took me ages to find, I couldn't remember anything from the article apart from the "memory heatsink" the retarded writer did at the start.(cf)Eclipse said:linkage to where you have discovered this?![]()
of all the problems i have seen with AM2 the memory downclocking is not one of them, i have put 4x1GB DDR2-667 PC2-5300 and i had not noticed any slow downs with XP32bitO-6 said:If install 4*mem modules on AM2 mobo will they slow down as they did on s939 (4xDDR400 worked as DDR333)?
nice, thanks. that's good to knowbanGerprawN said:It took me ages to find, I couldn't remember anything from the article apart from the "memory heatsink" the retarded writer did at the start.
http://www.legitreviews.com/article/347/4/
The bottom paragraph...
but atm with DDR2, K8 prefers bandwidth to be sacrificed a bit for "speed", or overall latency. there's so much bandwidth, the core doesn't know what to do with it. lower latency will be the way to go to get the most performance.Tetrahedron said:sorta..
10 lane highway speed of 40mph = 40x10 = 400
20 lane highway speed of 30mph = 20x30 = 600
i would rather have more bandwidth and lesser speed.. allows for more throughput overall.
Spazilton said:Thats assuming there are enough cars (Data) to saturate your Highway.
(cf)Eclipse said:people still believe that eh? perhaps you should take a look at this. AMD HAS NOT changed the spec to 200mhz at 2T for 4 double rank modules.
http://www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/26094.PDF
go to page 182
yes, but the extreme majority of 512mb and all 1gb modules are double rank, so that point is kinda moot, unless you like using 256mb modulesdrizzt81 said:um, I am looking at that page: 4 DIMMS, single ranked = 400MHz, 2T. 4 DIMMS with 2 double ranked and two single ranked = 400MHZ, 2T
Tetrahedron said:yeah like who really uses all of 2GB of memory that much anyways.. I dont so... so why get 2GB or even 4GB?
even when I have photoshop, 3ds max, media player, crytek sandbox editor, browser (with multiple tabs open), trillian with all of em cranky out renderings 2GB of memory is not being used.
so yeah.. I dont even fill my highway up with cars with 2x1GB modules.
(cf)Eclipse said:nice, thanks. that's good to know![]()
sadly true.drizzt81 said:I guess we will not know this answer until someone finds a technical document from AMD with this info, now will we?
That would apply here... If only you could change the bit width of the memory channels. You can't, so you've got to work with 128bits in dual channel.Tetrahedron said:sorta..
