AM2 5000 or New Vid Card?
IceDigger
I currently have a amd 4000 am2 cpu with 2gb 800mhz ram and a x1800xl video card.
Looking to spend only $300 in my upgrade. What would be better, a x2 5000 or a newer video card?
It all depends on your goals. If you want better gaming performance, go for the vidcard. If you want better all around performance (except gaming), then go for the CPU. The CPU doesnt affect gaming as much.
If you do lean toward the video card I'd suggest waiting until you can afford an 8800GTS, which is around $100 more than your budget in order to get a decent bump in performance.
