Am I visible?
Status
Not open for further replies.
vinnie
Trying to find out if I have been un-invivisibled yet. I was invisibilised about 7 years ago because I admitted to using banner blocking software. Now that everyone is using firefox or equivalent, I was wondering if that kind of ban still held.
If a non-moderator can see this, then all is well. If not... I will check back in another 7 years.
Yah, you're visible. Never heard of an "invisible" option at a forum - if you do something against the rules it's typically "Banned" and that's about it.
That is called Coventry and it is universal ignore. That was a long time ago....6 years to be exact. You are visible and will stay that way. You're good to go. :cool:
You were put in invisible mode since you made our ads invisible.
Status
