XLeezardx
[H]ardChef
- Apr 30, 2005
I dont really know what im doing, but whatever im doing, it made my games run alot better.
Heres my rig:
AMD X2 4200+ with Stock HS/Fan
Asus A8N-SLI
2GB Corsair XMS PC-3200
EVGA 7900GT KO 512MB with Stock HS/Fan
Antec 550watt Power Supply
Coolermaster case with with Stock 120mm Fan
This is my first time overclocking and I am AMAZED! Im sure what im doing is not right and could probably do better. I hope you guys can point me into the right direction and help me get the best performance out of my PC. What I did was I went into my BIOS, enabled AI overclocking program within the BIOS and did a 10% overclock. CPU was set to 220mhz and I did not touch the RAM settings since I have no clue what to do with RAM. I let my Computer start and its not running 2.4GHZ from 2.2GHZ @ 45C ide tempature. I then Overclocked my Video Card by using the "detect optimize" under in the Nvidia settings. Stock is 560/1550 and was overclocked to 590/1624 @ 59c idle tempature. I ran Oblivian and F.E.A.R at their maximum resloution with a few things turned down and it ran better than before, it now playable. Before my games was not smooth and hurt my eyes moving the mouse around. My unregistered 3dMark 2006 score went from 5237 to like 5615. Everything ran great, no wierd artifacts and no system crashing. Of course im a bit scared so i set everythign back to stock before i go all out and get overclocking fans and heatsinks. So what do you guys think? Any advice? Thanks in advance
Heres my rig:
Asus A8N-SLI
