I currently have an e6400 Conroe L2 revision. I've been reading around the forums as far as temperatures, and mine always seems lower than other people, so I wanted to double check with you guys.
My FSB : DRAM is 1:1
412mhz x8 running @ 3.3ghz (Bus speed 412mhz / FSB 1650mhz)
Vcore 1.408~1.424v
Memory Voltage @ 2.1~v
NB voltage 1.5~v
Tuniq Tower @ Medium speed
Right now, Rivatuner and speedfan are showing the CPU temp as 44C, and the two cores anywhere from 50C to 60C. As of this writing, Orthos has been stable for 23 minutes. [ *edit* crashed @ 23 minutes / Lowered fsb from 425 to 412 and fsb from 1700 to 1650 ]
Are these normal temps or are they too high? The same with the vcore: is it too high?
Which temperature should I focus more on: The 2 core temperatures or the cpu temp?
Also, why does the multiplier jump from 6x to 8x on load?
Vcore 1.408~1.424v
NB voltage 1.5~v
