I just got a 2007FP (S-IPS) and overall it's one heck of a monitor but there's 1 flaw that's preventing it from being on par with a CRT for gaming performance.
If I run the LCD at 1600x1200 (native res) and run a game at a fixed aspect ratio (640x480) there is no lag at all. The picture looks microscopic (black bars), but it's as smooth as my CRT running at 120hz.
If I downscale my resolution to 800x600 and run the game at 640x480 it actually looks pretty reasonable. The problem is there's a small amount of "chop" associated with the image being displayed.
The only game I play is very chop sensitive. There's about a 600 width bar ranging from 0% up to 100%. My job in the game is to hit a specific location on that bar (a moving rectangle scales the bar), and then hit a small area when that rectangle makes it way back.
It's very easy to tell when this bar is smooth or chopping.
Since the monitor seems to be able to display the game with no chop (native res + fixed aspect ratio) maybe there's some setting I overlooked to get it working in its non-native resolution?
Btw setting the display at 75hz (nvidia's cpanel) when it's running at 800x600 was the worst choice imaginable. The chop was amplified so much that it was silly.
