Am I missing 70gb somewhere???
jaaaaakke
So im looking at my computer and it says that 342gb free out of a 465gb harddrive.....when i go to my harddrive, it says that I only have about 50gb on the harddrive...........so if im using 123gb, wheres the other 70 or so from??????????
a 465gb hard drive?! doesn't seem logical.. but whatever capacity your hard drive is - that's it's preformatted capacity. Formatting the drive removes some of this free space. It shouldn't, however, have lost any more than say ~40-45gb.
500GB HDD = 465GB.
OP: Is the OS on this drive?
Determining drive capacity can be confusing at times because of the different measurement standards that are often used. When dealing with Windows and Mac based systems, you will commonly see both decimal measurements and binary measurements of a drive's capacity. In either case, a drive's capacity is measured by using the total number of bytes available on the drive. As long as the drive displays the correct number of bytes (approximate), you are getting the drive's full capacity.
Decimal vs. Binary:
For simplicity and consistency, hard drive manufacturers define a megabyte as 1,000,000 bytes and a gigabyte as 1,000,000,000 bytes. This is a decimal (base 10) measurement and is the industry standard. However, certain system BIOSs, FDISK and Windows define a megabyte as 1,048,576 bytes and a gigabyte as 1,073,741,824 bytes. Mac systems also use these values. These are binary (base 2) measurements.
To Determine Decimal Capacity:
A decimal capacity is determined by dividing the total number of bytes, by the number of bytes per gigabyte (1,000,000,000 using base 10).
To Determine Binary Capacity:
A binary capacity is determined by dividing the total number of bytes, by the number of bytes per gigabyte (1,073,741,824 using base 2).
This is why different utilities will report different capacities for the same drive. The number of bytes is the same, but a different number of bytes is used to make a megabyte and a gigabyte. This is similar to the difference between 0 degrees Celsius and 32 degrees Fahrenheit. It is the same temperature, but will be reported differently depending on the scale you are using.
LOL at half the people not even reading the thread before launching into the binary vs. decimal debate. That isn't the issue here! RTFT!
OP: I would try out a program like Sequoia (SP?) that gives you a nice graphical representation of what is taking up space on your harddrive. You might have some automated windows system restore files taking up a lot of hidden space as well.
