matstars said:what do i say?
blackrino9 said:ZIF = ZERO INSERTION FORCE
hrmm..... i dont really get it, but if it works, it worksBlindedByScience said:...I thought someone would have mentioned Kyle's favorite trick - use the barrel of a 0.5 mm mechanical pencil. Works like the bomb on Intel CPU's (not that I've ever needed to do such a thing...) I can't imagine the pin diameter on the AMD's are significantly different, but that's a guess....
Cheers - B.B.S.
BlindedByScience said:matstars - I'm the guy that changed your thread title. Per the rules, swearing in thread titles is forbidden. I've been told that applies to "implied" swearing as well; so acronyms, clever mispellings, etc. are not allowed.
blackrino9 said:Use a mechanical pencil to gently bend the pins back into place and you should be GTG.
blackrino9 said:...very gently try to straighten the bent pins by squeezing them with needle nose plyers. DON'T PULL! Just squeeze gently. You may be able to get them straight enough that they will go in.
i was thinking of the same trick... but you got here before meBlindedByScience said:...I thought someone would have mentioned Kyle's favorite trick - use the barrel of a 0.5 mm mechanical pencil. Works like the bomb on Intel CPU's (not that I've ever needed to do such a thing...) I can't imagine the pin diameter on the AMD's are significantly different, but that's a guess....
Cheers - B.B.S.
uhoh., u mentioned "GOD"... a flamewars about to start..lol, always the same when religions are brought upOldPueblo said:I'm afraid your prayer had nothing to do with it. God prefers Athlon64's (FX to be specific).
