where do you get your facts?Originally posted by Keem
heatsink jerk = hotter = slower
Thats just one of many possibilities also yes, if something like ram isnt seated right (theoritically) it will be slower connection
Hard drives when they start to die go SLOW trust me I speak from experience...Originally posted by jwill
yes if a heatsink isnt seated right heat wont be transfer aswell which would make whatever run hotter, but not any slower.
just like The_Sub said, it either runs or it doesnt. id have to see some proof otherwise.
The HDDs produced today do not have problems if mounted at angles. Having one mounted at an angle is very different than taking one and tilting it while powered and in use. He statedOriginally posted by djnes
..... You may have bumped a HDD so it's sitting at an angle, and not flat, or vertical. HDDs do not like running unless they are flat or vertical, which can cause one to slow down. If you want prove of this, power up a hard drive out of a case, and while it's transferring a large file, tilt it. And, they could also be dying, in which case they'd slow and slow until their last breathe (spin).
Which to me means that it wasn't running and therefore shouldn't have effected the drive(s). Now a dying HDD.. Well I am not sure about that. I suppose that the motor that spins the platters could be giving out and slowing down. Thus efecting transfer times and such. We never did get a good deffinition of what "running a bit slower" was.I bumped my box really hard when I was taking it to a LAN ......
virus check
