SamuraiInBlack
- Oct 10, 2003
So I decided to turn my computer into the closest thing to a folding powerhouse that I own, meaning I would utilize both cores on my E6300 as well as my Visiontek 4850
The problem I am concerned with is whether or not I have this properly configured. Due to potential overheating issues (and being in the most heat retaining room of the house) I am not running everything full blast. I have the console version for the CPU set properly as far as I can tell, as both cores are loaded to their respective percentage of usage and don't stray from it much, if at all.
I also have the GPU systray client and I have it set top approx. 90% usage. I don't go the full 100 because even on my desktop after awhile it starts to distort color, so I took that as a hint that I should slow it down a little. I have the machine ID set to 3, since machine ID 1 and 2 seem to be for cores 1 and 2 of my Core 2 Duo, so I assumed machine ID 3 would be the GPU.
The problem here is that when I go into Catalyst Control Center to monitor my GPU usage, it fluctuates between 4 and 30%, but never seems to ever come near the 90% I stated.
So am I doing this right? Am I running one too many clients? Do I need a third party monitor for GPU usage?
