Am apparently using more memory than my board should allow for... HELP!
Riptide
I am using a Chaintech ZNF3-250 motherboard which on their website and in the manual lists a maximum of 2.0GB of DDR400 memory...
I just bought 2 1GB sticks of Kingston Hyper X and put it in and it ran great...
then i decided to put in a stick of my old 512MB Corsair Value Ram and it shows up in the bios, and in windows... and it works fine if not better than 2GB did...
Any thoughts?
Its super wierd.
Thanks,
riptide
Memory controller is on the CPU, so why would it not work?
==>Lazn
well the board BIOS revision lists 2.0GB as a maximum for the motherboard with PC3200
PC2700 you can go to 3GB...
my ram isnt underclocked or anything either...
running at full speed.
its wierd.
So are you saying you have a total of 2.5 GB and it works fine? If so, just enjoy it.
Are all 3 sticks DDR400. Knowing s754 boards, they take up to 2gb of DDR400 (which can only go in the 1st 2 slots I think) or 3gb of DDR333 and below using all 3 slots. One shouldn't be able to use all three slots with DDR400 unless the board is different or the mobo downclocked the RAM speed. Either way, enjoy your 2.5gb of RAM. I only have 1 gb of DDR400 in my rig.
