Althernative ATX Sleeving Idea
n64man120
I finished sleeving my PSU but the ATX and P4 power connectors were too difficult to remove, I couldnt seem to get it off. Rather then spending 25$ on the remover I thought of getting reflective silver tape and wrapping those wires with them (All my other sleeving is reflective silver). How do you think this would look? And anyone know where I could get some tape like this? Thanks
tape's been done before, it looks pretty ghetto unless you spend a lot of time on it. btw, you spelled alternative wrong.
Anyone have a suggestion? Or where i can get some nice metallic looking tape? I want to try to wind it in a spiral really carefully... hopefully that wouldnt look to bad.
Thats for the molex power ones, i'm talking about the big one for the ATX Cable
the pins inside the socket are the same on the ATX connector as on the molex plugs
<edit> whoops, my bad. Just checked--they are differend </edit>
Was gonna say....
The ATX connector is a pain. Even if you manage to get the pins out, trying to keep the wires in the correct order is a hassle. Here is the best suggestion if you still want to try to take the pins out. Take some thread, weave it between the wires in/out style several times. Do it close to the connector so you can put the sleeving on without covering the thread. Then, use a small needle to bend back the retaining piece on the pins, slide out, put on sleeving/heatshrink. Once done, rebend the retaining pieces back out, slip in socket, your done.
