Alternative to MBM5?
biohazard_nz
Is there any other motherboard/temp monitoring software apart from MBM5.
I am looking for an Alternative because reports everything wrong on my SN95G5.
Help much appreciated
THNX,
I concur. Speedfan is great, possibly better than MBM because you can visually graph your changing temps, voltages, speeds, ect.
i used to use MBM5, and while it may be more configurable, speedfan is simple, small, and predictable.
Another vote for Speedfan. One day MBM5 decided to stop detecting my LM90 Remote sensor (CPU temperature), and would not return (after a reinstalling of MBM5 and even a reformat). Speedfan picked my temps up fine.
So it should be straightforward to configure then? Speedfan that is.
(I've got an A7N8X-E Deluxe v1.01, and it has some odd configuration on the socket and diode sensors, seems almost as though it's averaging somehow)
Another fellow recommended 8rdavcore.
another vote for speedfan because for me, speedfan is alot more accurate than mbm5, my 12v rail on mbm is always 11.88 and down....
on speedfan, i get 12.03 to 11.97 :) sweet hehe
I use speedfan as well.
but i notice some discrepencies with it.
MSIs CoreCenter reports CPU temps of 48*C/123*F
SpeedFan reports 45*C/115*F
What do you think is causing these differences?
I havn't tried to get MBM5 to work on my K8N Neo2 yet b/c I can't find the proper mobo.
