SupraSkylineSTI
- Oct 13, 2006
Would you be able to use the following device instead on TH2G ?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817707056
Two display outputs and a second one on the video card, which makes it three.. Right ?
I'm probably getting something wrong with this, but it looks alright.
Less than Nearly half of TH2G.
Will everything be the same? Thanks.
