I'm considering alternative methods of mounting a PCI-e soundcard, in this case an Auzentech Home Theatre HD 7.1. It needs to be a secure and safe solution as it's an expensive piece of hardware. First and foremost, I want to keep the card as far away from all the EFI and nonsense going on inside the case as my speakers and headphones are quite sensitive. I have some buzzing issues, my 285 GTX refuses to play nice, and there's only one PCI-e slot available to me (right next to the video card). I was initially looking at simply moving the card away from the GPU using this, but I've been unable to devise a safe alternative method of mounting it internally, not being able to employ the usual backpanel slots and screw mounts. My next thought was getting some kind of enclosure and mounting it externally, but the cheapest solution I can find would be a micro or small form tower of some kind. Even then, I would have to daisy chain at least two of the PCI-e extender ribbons to reach and I'm not sure how that would effect performance.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
