Alternative APC UPS software?
bitgod
So just hooked up a new APC and installed Powerchute PE, and I have to say I'm very underwhelmed by it. I hadn't been monitoring my previous APC, so this is the first time I've looked at Powerchute.
I know with SW that came with an old Belkin UPS I used to use, it would show me all the numbers for the unit, but Powerchute pretty much only tells me the battery charge %, battery load, and input voltage. Admittedly those are pretty much the most important numbers to me anyway, but I'd like to be able to go through and see all of the numbers I'd see on the UPS' display anyway.
Has anyone seen/used alternative SW that will give you all of the unit's readings? I'm assuming that possible, maybe APC gimps that for some reason?
