Is there a way to install windows onto an empty HDD, while inside windows, without having to restart anything? I doubt there is a method, but I figured I'd check. So, here's the problem:
For some damn reason I can't get past the hardware detection while installing from the boot cd. I recently installed XP 64, but found I don't like it and decided to switch back. I haven't had any issues with my comp in the past, everything is seated properly, all unneeded devices were either disabled in BIOS or physically removed from the system, yet setup still craps out immediately after booting from the install disk. I verified the integrity of the disk incase there was a problem with the data, but everything checks out ok. I've tested two different install disks at this point, one is just a regular install, the other a slightly modified version, both have SP2, and neither work.
I think it might be a problem with my graphics card, an ATI X300 SE (I know, it sucks), but I don't have anything else to replace it, so I can't really take it out. Here's my rig setup:
AMD 64 3500+ Clawhammer, no OC
2x512 Corsair, normal timings, no OC
250gb SATA HDD
100gb SATA HDD
MSI K8N Neo4 Platinum SLI
PCP&C TurboCool 510 SLI
ATI X300 SE PCI-E
I'm incredibly frustrated as I cannot isolate the problem, so if anyone has any suggestions or possible solutions, I'm up for trying them out.
250gb SATA HDD
100gb SATA HDD
ATI X300 SE PCI-E
