pbXassassinX1524
- Nov 24, 2003
Okay, now a while back I saw that sandra was telling me that my vcore was higher then it should be. Not at this time it wasn't so bad, but now the voltages are WAY pver what they should be, but I never have any problems with stability in my system (other then when I botched a display driver install.) But anyway, I was running prime95 yesterday just to see what my temps were running at, everything checks out fantastically. But one thing, my vcore was being read as about 2.9+ getting up to about 3.06 volts, this is rediculously high, I'm hoping that its not reading it correctly or I've got a big problem.
I have never touched any BIOS settings that have to do with the CPU voltage or even the FSB, and if I was ever in trhat section of the BIOS even if I did it by accident after changing some other setting I always exit w/o saving anything, then go back next time and change back the setting I mean't to go into.
What do you guys think of this, wouldn't my CPU be like near blowing up if the voltages were this high?
Also I don't know if this is normal or not, but in CPUz my speed rating on my CPU will fluctuate from time to time (2999 to 3001) is this normal?
Okay, sorry for the novel, I'm just a little concerned about this.
