Alphacool SLI bridges
Bigbacon
Anyone used any of the alpha cool SLI bridge things?
these:http://www.performance-pcs.com/cata...lphacool-gpx-sli-connector-dual/category/979/
I'm using Alphacool blocks on some 980 cards I have coming but I'm unsure about using this. they press fit on using dual o-rings.
I'm not sure if I need the dual or triple one because of my layout. I assume the dual one would work but it is hard to tell. the SLI480s I have now are next to one nother but are dual backpane cards with a 1x connector between them. I assume the dual one will work for this as I assume these aren't setup to make cards single slot right?
Alpha cool's website is no help at all as #1 there are no manuals posted for these and #2 the photos are SUPER tiny and you can't click to expand them.
Shoot an email to Alphacool with your mobo (and used slots) and the blocks you are using. They will be able to help you.
Figured it out. The bridges kind suck. Plastic, it feels cheap,and the double orings are the only thing that hold it in place.
Seems sort of restrictive also.
