Cantonious
- Jun 22, 2003
Alright, have an Abit A8N32X in a LianLi PC1200, so the motherboard is upside down, and the PWM reaches 64C in some instances. That's something I'd like to get a handle on, and I'm thinking the following might help.
NexXxoS NB-SLI Northbridge
Mosfet AN8 Series
Now these are both small diameter, so I'm thinking the appropriate connector is in order but I'm not sure if it's the right one. If I use those, I would need the appropriate tubing and then finally, a radiator, t-line, and pump, but I'm worried most about the tubing fitting the barb on the t-line, pump, and radiators. So, after looking over all of the stuff I'd like to get, the deal breaker is this, will 8mm ID fit on a 3/8" barb?
For what it's worth this is my first small bore kit. I already have a DD CSP-MAG 12v pump, TDX for AMD, and BlackIce Extreme 2 all on 1/2" but I'm wanting to put a second CSP in, along with the parts mentioned above, on 2x120mm BI Pros. Advice?
-C
Mosfet AN8 Series
-C
