Alphacool CP 1510 bad flow
Hello All, I got a new Alphacool CP 1510 with adjustable Volt 12-24 has anyone used this pump if so any trick to get this thing flowing. I have had it for two days it is set up
Pump discharge to Rad. Rad. discharge to CPU inlet CPU Discharge to volt reg inlet dis. to North B. inlet NB to SB inlet to res inlet res to pump inlet.
I can see air in the upper half of the inlet and outlet of the Swiftech Rad. The Only way I can get it to pump a little it @ 24V I had a swiftech 655 and it went bad and the two years was up so I got this one that said it put out 1500L/H. I hope this info is all any one needs or one of You knows some trick of Maybe I need to change the loop. All I know is that pump should push a lot of water. Oh and there is a noise sounds like a small amount of water moving around inside the pump that is the best way I can put it into words. I Am thinking new pump and this one is crap.
Thank You.
