Almost finished building my 1st pc...need some help
Biff Hardbody
I'm almost finished building my 1st pc. I've run into something I am unsure of though. My case (lian Li PC-65B) comes with 2 USB ports, and I am unsure of where to connect the wires. I've consulted both the case and MB manual, but no help.
Here is my motherboard-
http://images10.newegg.com/productimage/13-131-499-02.JPG
I am thinking its one of the small blue ports near the bottom PCI slot. From left to right the slots are called USB78, USB65, and COM2.
However, there are MANY cables to connect from the USB ports (Data+1, Data-1, VCC 1, Ground 1, Data +2, Data -2, VCC 2, Ground 2).
Is it necesary for me to connect these cables in order for my pc to work? I already have two USB's in the motherboard themselves. Thanks...
yes, that little thing on the mobo is called the USB header, and yes you have to match up all those little connecters coming off those usb ports onto their appropiate pin. ill tell you right now, its a pain in the ass, big time, but it can be done
Thank you for responding! Must I do it? I don't really care about two extra USB ports. I'd just like to get my PC up and running.
