allocating network bandwidth?
Hi everybody,
is it possible to do this, do i need a special router?
my router is a linksys wrt44gl, and i did call their tech support regarding this, they weren't much help though.
we have good bandwidth, 8/2, prob gonna bump up to 12/5, it's cable internet...... problem is say i'm using utorrent to share some files, despite the speed at which it's actually downloading at, or where the limits are set for that matter (like 1/2 of total bandwidth max capacity for example), the application just takes everything, rendering internet use pretty very slow, and my roommate with no ability to play online games.
i've been on utorrent forums and didn't get that much there either, except someone sent me a link that had a "fix" for a variety of things, which i went through anyway, and just ended up with slower download speeds, and no better response with either issue. so i was wondering if it's just my router, don't know much about routers, and if it's possible at all to do it, or do something, so that i could allocate specific (or even just even split, or whatever) bandwidth on 2 or 3 computers. basically so that no one person can "hog" all the bandwidth (usually me), and other people can do what they want to and be happy.
so, it's one cable modem(idk, comcast emta), to router(linksys wrt54gl), and then hardwired to pcs.
they said to drop another line in, it would effectively double my bill, which seems like bs, because they put however many lines they need to the tvs, but so anyway don't want to go that route, just want to jack up the speed, and try to split it equally.
Can I do this?
side question: much of the media going through router is blu-ray, should i be using a gigabit router? there's just 2 of us now, but that's why i hard lined everything, if add third would be nice to do wirelessly, would gigabit router accomplish this?
thanks a lot,
rlr
Ok... best as I can figure you have broadband, and when you torrent the internet becomes unusable.
The easy fix is to throttle your torrent download speeds and max number of connections, easy to do but varies based on the torrent client.
Otherwise you're basically talking about doing Quality of Service which by default I'm going to doubt your router can do unless you can load something open source like DDWRT on it.
My advice- go with the easy fix. ;)
Did you try limiting it to 1/2 total in utorrent, or with your router's QoS settings?
you set the max allowable bandwidth for utorrent in 2 spots, iirc.
1 is for unscheduled.
and then you can also set up a scheduled.
if you're limiting the bandwidth for scheduled, but NOT turning the schedule on, then nothing is changing.
but then again... I have no clue what changes may have been done since 1.6 if you're using a newer version
i was limiting the d/l & u/l speed, by more than half, experimentally, at first but it didn't affect internet or gaming speeds at all, still crawling. i was using the limits in utorrent preferences. I spoke with a linksys tech support person, who had me make an adjustment, can't remember what it was exactly, but it didn't help. and that's a wrt54gl btw, not 44.
thanks,
rlr
Its been a while since I have torreented anything but I adjusted my bandwidth via my torrent clients UI ( looks like you already did that ) and adjusted the number of connections. I had a modem that couldnt handle torrents till I did both of those . So, maybe try limiting your number of connections and see.
if i'm not doing any scheduling, there's only one adjustment for d/l, u/l speeds right, in preferences?
my roomie is gaming right now, so unfortunately can't open utorrent to check, but do you mean "max number of global connections", i believe it's called? that one is the one that's around 750, in my case, but there's another connection number setting pertaining to peer connections, i think, that is a lower number, like 10. do you mean both settings, or just the global?
Thanks!
rlr
for QoS settings, i have wired and wireless options, they are both disabled. under wired there is one for devices, one for ethernet ports, and one for applications. i would assume to just use ports? or would it be easier to select applications, and set utorrent to like idk, low priority, when necessary?
for ethernet port priority, do i set the ports for each pc at medium or something, and then it will get split up better, or equally even?
thanks a lot,
rlr
