Allied PSU, are they good?
slaya
Hey, someone is selling an Allied 350Watt PSU, I would like to buy this for my old system which is in need for a PSU. My question is, is it a reliable brand, or should i buy a retail Antec or something three times the price?
Allied should be fine if you don't want to pay more. They come standard with some cases sold by Newegg.
I think the really crappy psus give the cheaper ones a bad name, cost doesnt always mean quality.
the 300w power supply that came with my first case was by brand "KING YES".
KING YES is not a good brand.
I have a couple of 400W Allied PSU´s, work fine, no spikes issues, etc..very cheap :D
OldMX
Yeah I think I've got one of those antec 400w power supplies for $33 off newegg. Haven't had any problems(that I know of) and cheaper than antec. I say allied is fine if you aren't doing any heavy overclocking or anything.
I personally can vouch for an Allied 430W PSU. I plopped one in on my former AMD system when my really generic one crapped out on me and I had no voltage problems. Keep in mind that I didn't have much of a mind for overclocking either, so I never tested that.
As agreed, it's an acceptable power supply if you aren't doing anything power intensive or have a top of the line video card and hard drive combo, that'll suck the life out of it.
Dark Assassin
I think it really is a gamble getting no name power supplies. Some of them work perfectly, but then there are other ones that will light on fire and kill all of your components. If you want to get a cheap power supply get a forton, I've heard good things about them or if you are really set on getting an allied psu then I would get a power supply tester from frozencpu.com to test it before I hooked any expensive components up to it.
Antec or Enermax all the way.
After buying an Antec and since my mate got an enermax, there is NO WAY I would get anything else. Over and above the best out there by far.
Allied == Deer == L&C == Foxconn == other generic PSU names
They all come from the same hole in the wall in china, and all will pwn j00 in a short period of time.
My basis from this is over 2 years of exp in a repair shop, seeing so many of the danged dead ones that you see listed above (plus KompUSSR's brand), destroying entire systems when they go out with a bang.....
Cliff notes:
1. Allied == teh no
2. Antec == teh yes
If your on a budget you can get a Fortron power supply cheaper then an Antec and they are just as good. As far as PSU's go always buy a brand name. Never sacrifice your whole system to being undervolted or overvolted.
Antec, Fortron, Sparkle, PC Power and Cooling, and Enermax are all good brand names.
A nice sparkle PSU should be cheaper then an antec and not much more then an allied ... any machine i build within a certian budget usually gets a sparkle PSU ...
