MisterDNA
- Feb 8, 2004
I've searched the board and have seen more than a few people have had problems with Gigabyte motherboard capacitors dying out of nowhere after a lead time of months to years.
My own GA-7VAXP has bulge and leak problems involving the two 3300uF 6.3V capacitors behind the chipset and cornered by the two filter choke coils.
The caps are GSC brand and, well, search for GSC in this article:
http://www.geek.com/news/geeknews/2003Feb/bch20030207018535.htm
Seems most Gigabyte boards starting with GA-7V are similar in design.
I can't run three DIMMs most of the time. I can't run my "ugly" 1GB BGA sticks higher than PC2100 if I have more than one stick. My DDR vtt is 1.2 (no clue if that's bad) my core voltage is 1.75 on an AXP 2000+ and when my FX5600 is running SoftQuadro, it freezes during certain wireframe tests in SPEC Viewperf 7.1 and reboots. The freeze point is dependent upon how many DIMMs I have installed. If I run three, it freezes sooner. If I run two, it freezes later. If I run one, it freezes, then resumes, then freezes again, then reboots.
Anyone else want to share their experiences?
