My cards only crackle every 7 minutes or so, but it's still annoying, and it shouldn't happen. Is it possible that this is because of a bad PCI controller or something? My onboard sound doesn't crackle at all, but it's on the PCI bus as well, so I don't know. I've only tried one PCI slot, should I bother changing it to another one?
Also, the PCI bus is locked by default, right? What's the switch called in the bios? enhance PCI performance? should it be on or off? :-[ It seems to crackle more when IDE devices are in heavy use, if that helps any.
edit: it isn't just a small pause in the sound, it's a LOUD click/screech. crackle is a bad word for it.
