Ok so I've found that the Alienware Graphics Amplifer is connected via PCIe 3.0 4x. If the laptop has a GTX 980M, what video card can I put in the Graphics Amplifer that will still outperform the 980M when running at PCIe 3.0 4x?
PCIe 3.0 4x shouldn't really hamstring a card's performance. There is an article on PCIe speeds on [H]ardocp. I'll try and dig it up. So pick something that is significantly faster than a 980M.
According to notebookcheck, the GTX 970 is about 22% faster, maybe a couple % lower if you figure a small amount slower with the 4x vs 16x. But then again, that's assuming your 980m isn't throttling either, which Alienware laptop do you have?
Well, budget couldn't stretch for a 980TI so ended up getting a GTX970. Still on the way so I haven't had a chance to try it yet. Hopefully it performs close to on-par with the GTX980M.
