Device Type
LED-backlit LCD monitor
Features
USB 3.0
Panel Type
Fast IPS Nano Color
Aspect Ratio
21:9
Native Resolution
3440 x 1440 at 120Hz (native)
Pixel Pitch
0.2325 mm x 0.2325 mm
Brightness
350 cd/m2 (typical)
Contrast Ratio
1000: 1 (typical)
Response Time
True 2ms (Gray to Gray)
Color Support
Color Gamut (typical): DCI- P3 98% coverage
Color Depth: 16.78 Million colors
Input Connectors
1 x HDMI (ver 1.4)
1 x DP (ver 1.2)
1 x USB 3.0 upstream port (Rear)
2 x USB 3.0 Downstream port (Rear)
2 x USB 3.0 Downstream port with 1 x power charging(Front bottom)
1 x Headphone-out jack (Front Bottom)
1 x Audio Line-out jack( Rear)
Display Position Adjustments
799.80 mm x 334.80 mm
31.49" x 13.18"
267773.04 mm2 (415.01 inches2)
Screen Coating
Antiglare with 3H hardness
Dimensions (WxDxH) - with stand
32.04"x10.77"x22.10"
Weight
15.67kg
34.54 lb
https://www.dell.com/en-us/member/s...acd=12309198375458460&VEN3=810805171733331701
Features
USB 3.0
Panel Type
Fast IPS Nano Color
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
Brightness
350 cd/m2 (typical)
Contrast Ratio
1000: 1 (typical)
Response Time
Color Support
Input Connectors
1 x HDMI (ver 1.4)
1 x DP (ver 1.2)
31.49" x 13.18"
Screen Coating
Weight
15.67kg
34.54 lb
