Alcohol in WC Loop
OCgamer666 said:
Im going to have to agree there is no danger to haveing alcohol in a closed loop
1)there has to be O2 for it to ignite
2)there has to be a flame or spark to ignite it (not many of those in a computer case)
3)Its safer because it wont damage components in the event of a leak(its non conductive)
I agree with this in a physical safety sense, but alcohol is hard on rubber and will evntually damage it. This includes o-rings and the rubber bushings found on water pump impeller shafts.
thewhiteguy said:
Using alcohol with a bong cooler could give you excellent temps! Just don't smoke around the computer :eek:
OCgamer666 said:
yes it would work but you would have a continuous supply of alcohol (exspensive but way cool)
Not to mention the constant headaches and eventual brain damage you'd likely have from constantly breathing alcohol fumes.
