AL2216Wbd vs 226bw vs 206bw
Benton The Race
I am looking for a budget monitor(under $300) to replace my giant ass FW900 CRT. I kind of got out of gaming so that isn't a big issue, I just want a monitor that has really good image quality for surfing, homework, and movies. So out of these three monitors what do you think suits me the best?
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009094
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001096
http://www.amazon.com/exec/obidos/ASIN/B000N5WNKM/ruggedelegance32693-20/ref=nosim
Any of those will probably be fine for surfing but they will all look like crap with movies. If they have backlight bleed (which is almost certain) it will be visible while watching movies with black bars or dark scenes and the picture will also look pixelated up close. TN panels simply suck for movies, i've tried a newer model Acer + a 226bw and was not impressed at all. The only way i could stand watching a movie was from about 8 feet away.
btw if you live in Canada please sell me your FW900. :p
I would stick with your CRT. I used to own the 206BW. It's a good monitor but image quality doesn't compare to a CRT. Mine was a TN panel. 226BW is probably the same deal, just larger. I don't know about the other monitor but if it's a 22in that means it's a TN panel and will have the same problems with image quality.
Spend $100 and get a bigger desk. It will look better ;-)
How did you figure a budget LCD will replace your premium designer level massive widescreen CRT?
I didn't figure that I am just sick of having my whole room look like shit every time someone walks in because I have a 100 pound monitor that requires me to push my desk 2 feet away from my wall just to use.
