http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=137
The D-tek white water is aluminum topped, and as I understand it, this will cause corrosion. Does this make the block a bad choice for me? I currently run a socket 478 system, but plan on moving to socket 939 eventually. That's why I want to go with a universal block like the WW or the Storm, but the storm is a bit pricy for me and the WW looks like it will perform within 1-2C of the Storm. I will probably be ordering a D5 from dangerden so I can get the MCT-5 solution. Will there be any long term effects of using the Aluminum topped WW with MCT-5 or is there some other solution I should be looking at?\
Thanks in advance.
Thanks in advance.
