AIW ----> TV Tuner?
2phastPRO
Slight problem....
My TV blew out on me during a Hurricane. Down here in Miami. I was just wondering...if I bought a 9600XT AIW, would I be able to hook up my PS2, DVD player etc. to my PC and use it as a TV? Or would a simple TV tuner do the trick? If so, any reccomendations?
I was going to go with the 9600XT AIW because I also needed a vid. card upgrade (9200 pro -_-) and it was in my price range ($188 at newegg)
Thanks in advance.
Yes you can play those on the TV Tuner card and AIW. You would have to manually switch the devices though as you can only plug one at a time into the card. They uaually provide a purple break out box that has SVideo in and Composite in.
Thank You.
Any reccomendations on TV tuners?
I just might save up for a 6800 instead of grabbing the AIW.
