AIW 9800 Pro TV Tuner Problems
[H]Tek
Is this possible? I overclocked my aiw 9800 pro to 410/360, but I have good ram sinks & a vga silencer. I was getting minimal artifacts on a pixel shader test, and decided it wasnt worth it so I brought evertything back down to stock. I have a 2500+ @ 3200+ speeds constantly...i guess we should bring that down and see if this is fixed, but it always ran fine before he overclocked the card.
anywho, now the tv tuner just shows a black screen with some static and some lines on every channel.
could this have been from overlclocking the card? how separate are the media components from the gpu etc..? thanks
And any suggestions?
if you are using atitool, install a 0.0.23 beta .. the issue has been fixed there
problem fixed, who would have thought it was atiTool and not a hardware problem
Thanks alot man! I had this problem all night, spent a couple hours going over every damn thing...:(.
