Airlink+ Router Help
I posted this question earlier in the month but it fell from the front page into the abyss without any responses......I know that someone out there knows soemthing about this subject.....So with the risk of flaming I will repost it. Thanks in advance guys.
I have heard that this router (AR315W) can be updated with another companies(Belkin or someone elses) firmware. The Marvell chipset has some functions that are unused in the Airlink firmware.This other firmware supposedly makes better use of the chipsets features. Fry's has been having some pretty impressive deals on Airlink+ equipment, but it appears that the firmware support is going to be thin from this company. Any help chasing this firmware update down would be appreciated.
Jeff
I have got one from Fry's. But it seems very poor performance something like connection dropped while I was just moving out of my door only 7-8 meters away!!!
I used my Dell D600 laptop with built-in wireless card to test it, which only supports 802.11b. And I config my router as a 11g and 11b hybrid mode. Does it cause the connection unstability and poor performance???
Any one give your advice is very appreciated! :confused:
Jeff,
I have checked it out on the web site. Yes, the Belkin, Buffalo, Linksys, Microsoft, Gateway, etc. and the AirLink+ use the same chipset from BroadCom. So I guess it maybe work if you update the firmware with another vender's. ;)
Worm, You may want to check the type of chipset the AR315W uses, in my research I have found that it uses the Marvell chipset. Again, I have read only one similar account were a guy used a Belkin firmware to update his Airlink wireless router (he didnt mention which one).
Jeff
Jeff,
I have compared the firmware files between Airlink AR315W and Belkin 7320-4. They are very different, from file size and extension.
Worm,
After a little more research I have found that Netgear WGR614 uses the Marvell Libertas chipsets also. There have been 4 different versions of this hardware so Im tracking down which one would match the Airlink+ hardware. For the $30 bucks I may just trial and error it, until I have a match. The Netgear firmware updates and support seem infinitely better.
Jeff
See:
http://www.linux-hacker.net/cgi-bin...5&Idle=0&Sort=0&Order=Descend&Page=0&Session=
Look into this guy's talking:
I got my hands on a Netgear WGR614 v4. However, unlike the earlier versions, this one is based on a Marvell Semiconductors 88W8510 802.11g baseband chip (with an ARM9 core) and an 88E6060 fast ethernet MAC/switch.
The earlier Atheros chipset was based on a MIPS core, but this one is based on an ARM. It looks like there were firmware issues with the earlier v1, v2 & v3 versions. Most of those issues are apparently not present in the v4, with the Marvell chipset.
Regarding hackability, the JTAG header is missing, but an unpopulated 4-pin header is present near the baseband chip. Flash ROM is a single 2 Mbyte (?) AM29LV8008t TSOP and DRAM consists of two v54C316162 1M x 16 EDO RAM (total of 4 MBytes).
Nothing much else except the voltage regulators, LEDs and RF section (shielded with a soldered metal shield). External antenna is not socketed, but comes with a braided coax lead that is soldered to the PCB.
So I moved the cap of the AR315, got the chip is Marvell 88W8510-BAN another is 88E66060-RCJ, the Flash Mem Chip is AMD AM29LV8008Tare, the RAM are 2 X CSI(??) IC42S16000-6T. Seems match the guy's info.
