Airflow vs. bigger rad
Ur_Mom
I have 2 radiators. A heatcore from DTek that will run a single Comair Rotron LOUD fan (TONS of airflow) and a dual 120mm heatercore that will run the 2 120mm fans (on a fan controller, so they will be quiet and quieter).
Which would get the better performance. I know the airflow is good, but so is the water staying in the cooler longer....
Decisions, decisions. Don't have the it 120mm fans yet, so not sure if I should buy them and test it out, or if someone has had similar experience...
I'd run two fans for more silence and if you need more cooling just crank up the speed a bit with the fan controller.
agreed! But could you use both? I used to have a single 120mm mounted outside the rear of the case with a radbox and the 2x120mm mounted at the top with a fangrille. This coupled with 3 quiet fans on a speed controller would be DY-NO-MITE! Sometime I'd run it with all three fans off just for kicks...;)
